Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Midrange lack of power GT125R Reply To: Midrange lack of power GT125R
Hi Marcel. Sorry for the delay between posts. Long story here so I’ll try to be quick. You know I emailed you about my uprated coils failing, well the uprated reg/rec has just died too. I’ve just tested the 3 yellow wires from the stator and they are all directly shorted to each other. Less than 1ohm resistance between all 3 phases. So I think I’ve found out why the new parts were failing. Also explains my poor sparking issues. Would you need pictures of my flywheel and stator to confirm what unit I need? I’ve spent so much money in this bike and it’s just decided to blow up all the new parts. I’m not a happy bunny and now looking at another god knows how much to fix her.
Okay I’ve just looked at the specs for the charging coils and the manual says between 0.6-0.9 ohms. So might be In spec then. I’m gonna retest
