Forums 🚦 RIDERS LOUNGE 😃 General Chat No spark on one side Reply To: No spark on one side
Mar 1, 2024 at 2:19 PM
#12442
Hi
I’ve tested the white and blue wire and the front coil black and yellow wire and these ok no wires broken . I have tested the two pin wire coming out of the stator and it shows 2 homs, I’ve also tested the stator the voltage regulator or (R&R) and the battery and both coil packs and all seem good And I do have a power jump box just in case I need a bit more kick ,
All I have to do now is test the harness, If that is ok then i’m stumped 🤔
