The SV and Hyosung both use Mikuni Carbs , but because of  Hyosung & Suzuki ‘s past relationship , the similarities would be there…
But.. Hyosung’s engine is faster than the SV’s if tuned right, i know it is, it may have different jetting than the SV.  Then there is also some small metal parts hyosung makes themselves by hand to join 2 carbs together , some metal parts to guide the cables properly etc , small little things , even the idle adjuster cable seems Hyosung made with the help of Mikuni.
I think this might also avoid Hyosung having to copy Suzuki entirely and pay licenses/copyrights for everything , hence you could argue their engines are similar but most internals are “Hyosung Made” for “Hyosung only”  so to speak.
The SV might have extra parts attached to the carb that Hyosung doesn’t need.   (Less parts , less maintenance to worry so to speak lol)
You could rob some parts there and there but don’t expect to copy everything from the SV 😉
