Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GV250 slowly raising of an oil level in the engine Reply To: GV250 slowly raising of an oil level in the engine
I have already changed the oil and the oil filter, but the problem remains. I suspect that gasoline would slowly come into the oil because there is no other fluids in the engine.
That would also be correct. It would cause hydro locking issues and many issues like soon replacing pistons, crank , cylinder heads etc….
Oil will smell of fuel.
This means carb floats need changing / adjusting , change float seats (because they jammed and allow fuel in to cylinders when bike is off) , change float seat needles , and finally look at investigating the tank tap and also fuel pump , if you have doubts, its cheaper to replace all fuel parts i mentioned than rebuild an engine 🙂
