Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Rear shock very soft suspension
- This topic has 2 replies, 3 voices, and was last updated 5 months ago by
LaserBeam.
Viewing 2 reply threads
May 22, 2025 at 12:45 PM #19601Bike Model = : Gt 125 r
How easy is the rear shock to adjust and is the rear shock easy accessable do I need to remove fairings or mounts?
May 22, 2025 at 6:30 PM #19604
Yes you need fairings off, then use jacks to rise the bike up safely.  Then remove the shock from under the bike , adjust it while it is out of the bike
ORÂ if you have very small strong hands, go where the rear brake reservoir is, use a C-Shock tool to rotate the shock a few more clicks until the springs feel stiffer.
May 25, 2025 at 5:51 AM #19622
If your rear shock is SOFT & boucnces up & down easily, it’s toast.It is very easy to swap that old shock for a new one.Here is how to do it:PS. If you need more specific info about Socket or Spanner sizes for this job, let me know.-----LaserBeam---->
// SHARE THIS //
- More
