Forums π₯ PiT STOP π§ Hyosung Technical Help How to treat internal rust in 2007 gv650 fuel tank
- This topic has 5 replies, 3 voices, and was last updated 1 year ago by
LaserBeam.
May 13, 2024 at 5:49 PM #13382
- Hi allπ l recently purchased a 2007 GV 650 carb model it has been in storage for several years and has surface rust in fuel tank,just wondering what can be done to clean this out or product available to treat it?
- lm in Sydney Australia
- Any thoughts or input would be greatly appreciated thank you in advance π
May 13, 2024 at 7:17 PM #13383
In Spain, we have a product called “Tankerite” and also “Restom”.
Another option is to use phosphoric acid; you have to mix it with water. I don’t remember the proportion. When there’s no oxide left, you have to clean the tank to ensure no phosphoric acid is left, and then conclude with a hydrocarbon-resistant epoxy resin.
May 13, 2024 at 8:29 PM #13385
If the rust is not to bad I always used small nuts & diesel & just swirl it about after removing the sender/pump etc.
May 14, 2024 at 10:53 PM #13391
G’day Rob, i’ll be doing a photo tutorial on Removing Rust from Fuel Tank.
If you have VERY MINOR surface rust you can use an ACID, like WHITE VINEGAR, or the products Ucvmn mentioned.
Simon’s method also works, where you place metal pieces into tank, swirl them around to lightly scratch off rust. Diesel may help keep tank walls from rusting too.
But the BEST METHOD & the only method any of you will ever use again is ELECTROLYSIS. You fill your tank with an electrolyte solution to the top, then you insert a metal rod like a steel bar or bolt into the tank & SUSPEND it so it DOESN’T TOUCH the TANK ANYWHERE, (ie. use wood or non-conducting material to hold the steel bar). Then you CONNECT the TANK & the METAL ROD to a battery, like a car battery, & let it bubble for 2 to 6 hours, depending on how rusted your tank is. DISCONNECT the BATTERY, pull out the Metal Rod & get ready to be really grossed-out cause it will be covered in a black, brown & red goo. That goo is most of the rust from your tank & it’s now stuck to that rod. Swirl the tank and empty the solution. Renew the soulton & pop another rod in the tank, if there’s still rust inside. When happy, empty the tank. Some people dry the tank with hair-dryer or heat gun. I’m just going to fill the tank with petrol or diesel a couple of time to rinse the tank & coat the walls with oiley stuff.
It’s like MAGIC. Just don’t zap yourself, don’t do it with petrol in the tank, don’t leave batteries unattended for long.
How do i keep the car battery from going flat? Good question; you are on the ball. Connect a car battery CHARGER to your battery for the duration.
π‘ CAUTION! Don’t leave battery or charger unattended – check them every 20-30mins. They can explode you know. We don’t want that.
-----LaserBeam---->
May 15, 2024 at 7:14 AM #13395
Hi guys thanks for the replies l have a better idea how to go about it nowπ
cheers Rob
May 15, 2024 at 2:32 PM #13402
The ELECTROLYTE can be several types of powders but a SWIMMING POOL electrolyte may be the best value. It’s mixed with distilled water or demineralized water but i cant recall the ratio. The electrolytes help the electric current pass through the water efficiently. This process is much faster & cleaner than waiting for acid to disolve the rust. I love the concept; hope it helps you all. π
-----LaserBeam---->
// SHARE THIS //
- More
