Forums 🚥 PiT STOP 🔧 Hyosung Technical Help GT125RC Front brakes and aftermarket exhaust
- This topic has 2 replies, 2 voices, and was last updated 5 years ago by
Clive Kemp.
May 23, 2020 at 10:40 PM #4447
Does anyone know if you can upgrade the single to dual front discs on a GT125RC and what addition hardware is need.
What would you recommend as an full aftermarket exhaust system
May 24, 2020 at 9:49 AM #4451
You will find a complete line kit at the shop
Then we need a caliper , front extra disc.
Then because the 125 has a smaller master cylinder , it may not have the power to push 2 discs. Usually we upgrade to a 650 master cylinder (it is what the 250r uses also). 650 MC usually says TCTC 5/8 under it.
125s can be marked 3/4. Sometimes not. It is possible i may have Daelim (korean too) 250 master cyl thats new and can push 2 discs but wont know until mid week when business reopens. Could be cheaper than trying to buy a GT650 master cyl. Only downside is that you will keep using the stock daelim lever ,so no fancy adjustable coloured ones 😉
May 26, 2020 at 11:52 AM #4457
Thanks for your top notch advice as always, I will wait to see the cost and viability of the Daelim MC 😎
// SHARE THIS //
- More
