Welcome Leo!
J&S , not been there for years.  I usually visit the doncaster one.
Tap “Shop” at the top of the site and start with the essentials only:
  • Oil filter ,  Air Filter , Spark plugs. Do a service on them.
  • Must change (because they have a bad name)  ==> OEM black caps for NGK ones   and  regulator   …..  All other electrics should be fine as they don’t usually break down that much , exacept the odd  brake switches   needing a change (happens to any bike)
    Use a YUASA battery that is YTX14BS   (get it from Halfords) as they will be newer  (some sellers online sell very old stock which is not good battery-wise!)
  • Chain if it has a 428 set   ,  go to Startrights in Leeds and tell them we sent you. They will sort you out with a fresh chain kit (standard set)
    If you wanted something more tried and true  ,  here is a 520 set conversion, that page will explain it all.
Everything else is just a matter of your eyes  (beauty is of beholder)
Don’t mess with the carbs UNLESS you know what you’re doing!  if she runs and idles perfectly ,  then the ONLY things you can do for now is:
  • Go to halfords and get ONLY “WYNNS FORMULA GOLD PETROL”  , pour the whole thing in the tank.  And ride.
    This will clean your fuel lines, tank, carbs ,  your cylinders a little bit etc….
    Do that once a month depending how many miles you do.
  • If you see “grey” colour fuel lines ,  Hyosung said replace them all because they are beyond the 4yr service limit  (too old)
    With this set here   and also this set here
To make the engine last longer:
  • EBC plates are good & trusted brand
  • Get valve clearances done (or checked)  , if you ain’t sure.   Myself or  Startright motorcycles will do it for you.
    Hyosung says they should be checked or adjusted around every 4-6k mile
  • Stay under 11k revs   (They don’t like redline for too long)
  • GT250 or GV250 cooler is the #1 gift for the engine,   it will really appreciate it.  The 125 cooler is “tiny”  , plus the 250 cooler is like a shield to stop dirt attacking the soft rubber intake pipes  (most difficult part to get!)  or rust up the carbs
  • Make sure it has stainless exhaust pipes   (Black Widow UK make them to this day)
  • Michelin tyres are your #1 friend  or alternative brand is  Bridgestone tyres.
    Avons  & Shinkos are like suicide bricks!
I am digressing , hopefully i covered most bases and go ride!     If you have other questions , ask away.
Stay away from sketchy websites  (they have a lot of complaints on TrustPilot)  they have “white & blue” backgrounds.   If something is very urgent, go straight to Startright Motorcycles Leeds , they are the oldest hyo dealer in UK and i personally buy their stock also to fill some parts in this website-shop.
Definitely stay off Aliexpress too!  Someone will tell you you can get cheaper plugs,   even they sell fakes , as below: (some chinese sellers on ebay/amazon don’t care either)
https://www.ngkntk.com/newsroom/blog/emea/fake-or-not/
