Forums 🚥 PiT STOP 🔧 Hyosung Technical Help Engine service manual?
- This topic has 3 replies, 2 voices, and was last updated 1 month ago by
♠️ MARCEL.
Sep 2, 2025 at 3:30 PM #20644Bike Model = : Hyosung gt250Ri
Hello, I’m just curious if there is any service manual that gives more information on things related to the engine. In the ones that are posted on this forum and the ones I’ve found online (which are basically the same found here) I haven’t found any information on things like adjusting the tps, torque numbers for engine bolts, valve clearances, etc.
Is there no Hyosung manual for that? Is there a substitute with a manual from another engine wink wink?Thank you.
Sep 2, 2025 at 9:48 PM #20647
use the carb version of the GT250 / GV250 manual for engine clearances and its internals
For EFi parts, take a look here:
Also , check the 650 manuals , (some , i mean SOME, efi parts are shared between the 650 and 250) , I uploaded a lot of 650 EFi manuals.
Sep 3, 2025 at 3:12 PM #20651
use the carb version of the GT250 / GV250 manual for engine clearances and its internals For EFi parts, take a look here:
https://hyoriders.club/forums/topic/fuel-induction-manual/embed/#?secret=Mhlbo8nVhW#?secret=lAy8RMTd3i Also , check the 650 manuals , (some , i mean SOME, efi parts are shared between the 650 and 250) , I uploaded a lot of 650 EFi manuals.
I hate to be that guy, but I really can’t find the service manual for the carb 250 on the forums either, just the owner’s manual
Sep 3, 2025 at 5:42 PM #20658
Try this one (tap here) , I will update the forum, thanks for the headsup!
// SHARE THIS //
- More
