I’ll send an email for a quote, the reg rec you sent me earlier, it will work fine with my bike right? Just to confirm.
I personally take the extra days to make the connectors and build the mini harness to fit your bike , i can never encourage wire chops to be fair (this bike just went up in smoke now, click here…..) , part of the cost is labour making those harness pig tails for the reg-rec and buying the special big connectors as you found out, they are quite specific size , and i have to be sure the regulator is also good after its stripped from another bike but it’s best to read the whole link i gave you earlier so you can understand what this kit is (what’s inside the box etc) (& extra time needed)
I do the same thing for various models like these down here
Upgrade Regulator Rectifier & Stator Generator – GV650 GT650 Hyosung {Carby & EFi up to 2013}
Upgrade Regulator Rectifier & Stator Magneto – Hyosung GV250 GT250 [EFi DELPHi 2011-2015]
And no worries about the uploader, if it works for others it’s fine. I’m okay with sending links.
Thank you and sorry again you have been a great help spotting bugs! – Technology is never perfect! – I will keep fighting, less hoops for you the better 🙂
