Dec 25, 2022 at 6:13 PM
#9281
Welcome to the site and happy holidays!
Can we ask ? (to get some understand of how it came to be)
- Total Miles on it
- When was the last time the carb had an ultrasonic clean?
- Any chance the inlet rubbers under the manifolds have cracks (Spray easy start on them to see if revs change = leaks)
- Any chance the “ORINGS” under the inlets have been replaced by now ? (CLICK HERE)
Bad orings and bad inlets = directly affect how the bike runs and how it starts aswell, its loosing / leaking air.
(Air VS Fuel (your carbs + fuel tap + pump) VS Sparks (Your coils, regulator, HT Caps, Plugs) - How handy are you with a multi meter to test electronics on your bike (Easy stuff to do but it helps you know if the issue is fueling or air or electronics that’s holding her back)
What kind of speeds do you get ? How does it finally start (tell us what you did to get it to start eventually?)
Do you use E10 ? (I reallllllllllllly hope you only use E5)
Let us know!
