Sep 12, 2024 at 7:31 PM
#14774
Hearing a relay buzz is normal , usually the headlight relay is the first one to “click” , then it turns the lights on. Followed with the “fuel pump” if it has one present instead of a bigf 30A fuse box for pump use, other relays control other parts of the EFi system.
Dash = See what he says and finds out.
See this topic below , and only pay attention to the video…. This should help you verify how the dash does the “needle rpm” sweep as soon as key turns on.
