Use e5 forever.  E10 will just ruin everything later even piston rings, as it looses speed as time goes on. = Valve Clearance time & Compression test time.  Can’t be avoided. I’d do this first before worrying about the carb, you want the engine proper sound first. get hard figures , don’t trust anyone who doesn’t write it down.
Change the oil.    (Open your “oil filler cap” near clutch cover, if you smell fuel = change the oil to Motul 7100 , 300v , 5100  or  Silkolene Comp 4 , Hyos love these oils)
Castrol ? = Run away from it.
EGR Blanks are sold on this shop for the engine side.
Airbox side = block the hole going to the EGR.
EGR is useless these days for carb bikes.
