Simon
  • Topics: 1
Under the tank on the left hand side are 2 connector blocks I’m pretty certain you have a bad connection there, just need a clean them & it should be fine, I had the same issue tried everything then realised that one of those connectors is where the ecu gets the signal from the coil to set the idle control solinode to the right position not had the issue again.
