First time I rode this bike in full darkness and I realized that the headlight was pointed downward about 10 meters in front of me. That and the blinding speedo light made for a bit of a spooky ride! I already played with the speedo brightness, but for some reason it went full bright again. I haven’t had a chance to figure out headlight adjustment on the Naked yet. I sure am infatuated with the sweet power spread of 4000 to 8500. ( in 250cc terms)
Personally i have not had hands on that particular rare headlight as UK commonly gets the roundshape versions (classical look) but speaking of lights,  have you had a chance to look behind it for some kind of thumb-based adjustment dial to rise or lower the beam aim  or look at the screws holding the headight  to the fork bracing , there must be a way to loosen 2 bolts (1 each side usually) then adjust aim, hold it there, then screw in tight.     Usually does the trick on my GV Aquilas.  The other GTRs i have have a thumb screw at the back as its too awkward to do it any otherway lol.
