Sep 21, 2022 at 4:24 AM
#8668
This also could be worth a shot; Along the harness , near the middle of the tank there is a diode (rectangular) shape white objected tucked away inside the harness tape. That’s for neutral. Also check neutral sensor itself, swap for another neutral sensor if in doubt.
I have been able to determine that its in the panel itself. The circuit board doesnt look that complicated with the cluster apart.
