John
  • Topics: 2
Hi John The GV250 is the frame same etc size as the GV125. I am 6’4″ with a 34 inside leg and size 14 feet, I find my GV a lovely fit. I did play with the back brake pedal to make it a bit lower (put a longer adjuster bolt in). Go for it, a GV250 is easy to work on and a joy to ride for the taller rider. At 950 Euros you will make money when you sell it on.
I wonder if the Aquila 125 has changed over the years, as I’ve just read a couple of reviews of newer (2020-ish) GV125’s being a bit cramped for longer legs?
