– Neutral Sensor (is it on?) , has it shown signs of abuse near the sprocket ?
– Clutch Lever Handlebar switch (no need to bypass but check circuit isn’t broken with a meter ?)
– Stator Pickup Sensor ? = Check it isn’t gummed up with dirt or fishy (plug is Blue & Green , white shell)
Check omhs under 200 , and report back?
– Engine Black Box all fully connected ?
I say black box as i am unsure it is EFi (ECU) or CDI Unit (Carby) – So will generalize them as the “black boxes”.
– Is the sidestand switch bypassed (recommended)
Also, do this safely! – Have a friend push you down a private road and drop to 1nd gear and see if the bike starts from the crank ?
We’re doing a process of elemination now. The fact the button says “click click” , means the circuit from the start button going to the solenoid isn’t broken (ie. wires okay)
I do hope in the end of all this its just solenoid or the 1st three electric parts above cutting sparks off.
Update us all and i will keep an eye on this topic.
