Jul 14, 2022 at 9:37 PM
#8086
I’ve run into another problem with the right fork, the rebound damper adjuster ain’t working, it just rotates all the way round but the left side works ok Can they be repaired or is it a new right fork ???
Sounds like you have to split the fork again to see what’s hopefully not broken inside though , otherwise if all fails , it should be OK to get another fork leg that looks “identical” to yours. Ignore 125cc and 250cc forks because they have different internals, the 650 is much heavier , and has adjustable tops.
