Because the only way the bike gets power to the dash is via:
  • Fuse/Relay box = as per simon
  • Ignition Barrel  (even its wires) =
    HOWEVER, if the mechanism inside the “key barrel” acts intermittent, it will translate to power cuts instantly
  • The entire loom itself may need investigating because if there is a “shortt” anywhere inside the cables fraying or touching exposed inside the tape jacket
    OR
    The 1 cable somewhere is touching the frame, that will instantly turn the bike off and possibly blow the fuse too
However, if the “rear”  and “front” lights stay  on ,  and the dash stays “off”, then investigate the dash area and its mini loom that tries to join the main skeleton harness.  Just a little heads up.
