Hyo71
  • Topics: 4
Hi,
That sounds odd, just few queries to get a bigger picture.
  • So everything works fine when running? The horn, lights all work?
  • Can the bike be riden normally right through the rev range?
  • When running, if you stall the motor, will the dash still stay on and let you start again?
  • Will it start after a certain amount of time has passed or if you take the key out and try a few times?
  • When you say turn off – do you mean use the kill switch to turn the motor off, or do you mean turn the key off?
  • Will it let you kill the bike with the kill switch and then start again or does the dash switch off when the bike dies?
