Hello , i have same bike and same problem my gd 250r is a 2017 model i swapped the baterry and it run well for almost a year now its the same cuts out unexpected. I´m wondering if its a fuel pump issue…
Clean the injectors and look at the fuel pump for any clogged debris or replace it, as sometimes it happens.
Also , check service manual and try to get Error Code from Dashboard to see if ECU stored any fault FI Error codes. This will make things easier.
You can also check / replace the relays on the bike.    Fuel Pump relay can sometimes fail.
