Nigel Eastwood
  • Topics: 3
Just a short update on my speedo problems. I did all the removal and clean up and rebuilt using good old lithium grease. All went back together OK and went for a test ride. Part way along the road speedo lept to the top of the clock and imediately zeroed never to work again. Sadly a combination of house moves that never happened and winter got in the way. Poor bike got layed up and a mighty search began for the wheel rotor, ending with a global  ebay search which showed only 1 preowned for the same model year from Leicester. Shortly after in January I did move house but the weather gods had their fun and things stood still. I managed to source a complete set of brand new clocks from Korea. Just last weekend did a full service and oil change, took the speedo off the new set and fitted it onto the old kit, and nothing happened.  After much swearing I removed the complete set of clocks put the new speedo back onto the new set, wired it all up fired up the engine and ran it around my yard, presto speedo back in action. It seems that the fuel guage/mileometer is also a computer that converts the analogue signal from the rotor to a charge that operates the speedo. That was the part that failed. Only issue I have is my bike only reads 14 miles on the clock and just a tad over 6000 on the defunct set. Phototaken for mr MOT man to show milage on the old set
