Leandro
  • Topics: 1
There is some units to sell here, not easy to find but exist…but even with scanner, therenis some question still missing answer
When you use the diagnostic tool to check the bike and do your own changes to the TPS, is it not responding better now ? Or do you suspect the TPS unit is suspicious (eg. a replacement is imminent ?)
No replace needed, the tps is fine, the bike is running fine…my question is the correct voltage of tps on gv650. I already understand that between 1.02 and 1.22 works, i suspect of the power of the response of throttle, just that
