Viewing 9 reply threads
    • #7369
      Leandro
      Hello guys, i does not have the s&t scanner to put my tps exactly on point…was reading on internet and found that tps must be adjusted on 28.82° degrees, but the only way is using the scanner…what i want is this voltage when tps is on 28.82°…some of you guys have this information?…service manual says approximately 1.12v. i want the exactly number
      Thanks
    • #7404
      Hello,
      I have just seen this topic,  So you have already downloaded the manual that is good!
      You either have a TPS that is 1 bolt mounted or 2 bolts mounted.   Notice i will share 2 pictures that show different voltages (not too dramatic though)
      and also this one
    • #7405
      1.20v – 1.30v could be a sweet spot but again we don’t know which TPS you have  , Korea is sneaky to switch things around while still producing the bikes.
    • #7421
      Leandro
      hello Marcel, thanks for answering, my tps is one bolt only, the service manuals i already read above five or six versions (change the years of printing)….like i said, i found a lot of differences between then, but, with the scanner i can put it exactly adjusted, with scanner in hand, you can adjust to 28.82 and se te voltage below
    • #7423
      Leandro
      here you can see the tps angle and below the voltage…..the correct point is 28.82°
    • #7437
      Leandro
      mine is one bolt and daewoo ECU, so my service manual is from your second photo, so 1.02 – 1.22, no matter the voltage between 02 until 22 works? what is the difference? on last page of this, we can see the year 2009 and the ecu on this manual é DAEWOO, so make sense to my model 12/13 here in brazil..i was testing just for curiosity, my bike was in 1.06 all this years since 2013, i change to 1.04 and what i see is that the bike works more slow to respond the throttle, but is just a detail, doesnt make the bike bad, i’m gonna try now 1.20 just to see the difference on throttle respond. lets keep testing
    • #7438
      That’s great man,  having a scanner will save you a lot of trouble! –  Especially with EFi bikes.
      I hope that tool did not damage your bank balance as they are not cheap or easy to acquire now 😉
    • #7442
      Leandro
      There is some units to sell here, not easy to find but exist…but even with scanner, therenis some question still missing answer
    • #7452
      When you use the diagnostic tool to check the bike and do your own changes to the TPS,  is it not responding better now ?  Or do you suspect the TPS unit is suspicious (eg. a replacement is imminent ?)
    • #7455
      Leandro
      No replace needed, the tps is fine, the bike is running fine…my question is the correct voltage of tps on gv650. I already understand that between 1.02 and 1.22 works, i suspect of the power of the response of throttle, just that
