Apr 21, 2022 at 1:04 PM
#7421
1.20v β 1.30v could be a sweet spot but again we donβt know which TPS you have , Korea is sneaky to switch things around while still producing the bikes.
hello Marcel, thanks for answering, my tps is one bolt only, the service manuals i already read above five or six versions (change the years of printing)….like i said, i found a lot of differences between then, but, with the scanner i can put it exactly adjusted, with scanner in hand, you can adjust to 28.82 and se te voltage below
