Ed
  • Topics: 1
Hi Edd I have have watched a vid on that issue and although I haven’t got any voltage readings as yet l did move it a bit at a time and it did have an effect on the bike and indeed it seemed to make a difference maybe when I can get the readings ( I believe I want about 1.4 volts at tick over ) l will get a better throttle response. Could the ixil exhaust and lack of high flow air filter have an effect . Many thanks for your reply .
About 1.25 volts i believe is the sweet spot,mine was at 1.08 volts as from the factory setting and i adjusted up to 1.25 volts.The service manual shows how to test with a multimeter.
