Luke
  • Topics: 2
I have finally found the time to strip and rebuild the carbs. Carb rebuild kit installed. Float height 7mm. Everything looks good.
I have got an “Updated & Braided Air/Vacuum Intake Line Hose Kit” from Marcel. Only problem is the photos on the website are unclear as to where the new lines go. I have only got one connection to the fuel tap, the photos show two. I am guessing the other one is the fuel tank vacuum? Does one go to the two inlet manifolds?
Help would be greatly appreciated
Luke
