Feb 11, 2021 at 7:14 AM
#5532
The plugs and air filter have only done 300 miles max. Not changed the pilot jets and the rubber plugs over the mixture screws are still in place and have no marks suggesting they have been removed. Choke is working fine.
I will take the carb off at the weekend and check the float bowls. If that doesn’t work I will give up on the bike and get another one. I’ve found another GV in Granada, only 4000km in the clock for 1400€. As soon as I can travel between Spanish provinces I will look at it. Ive got no more hair left to pull out on this bike.
Do you have an air pipe diagram so I can make sure all of the pipes are connected properly?
Thanks for all of your help.
