Feb 10, 2021 at 5:18 PM
#5526
Hi Luke, have you checked the operation of the choke could it be itโs stuck in the on position! when I got my bike the choke seemed to have no effect when I pulled it on, when I checked it out the choke cable going to the carb was not operating correctly, just a thought as yours is obviously running too rich. Also when you had the carbโs off did you check the float levels?
The choke is working fine and not sticking. I didn’t check the float bowls. Can I check them by going in from the side or do I have to take the carb off again?
