Feb 10, 2021 at 5:07 PM
#5524
Hi Luke, have you checked the operation of the choke could it be it’s stuck in the on position! when I got my bike the choke seemed to have no effect when I pulled it on, when I checked it out the choke cable going to the carb was not operating correctly, just a thought as yours is obviously running too rich. Also when you had the carb’s off did you check the float levels?
