Jun 1, 2020 at 8:59 AM
#4516
The wire have to be connected the switch closes the circuit, try that first
Yes I done that Simon but there is no noticeable difference. Battery fully charged, turn the key and system whirrs into life, the neutral and F1 light up, display keeps changing from F1 to 0, pull in the clutch, press the starter, it sounds like it might start then the clicking takes over and the neutral light flickers on and off. The display goes black then shows 888.
When I reconnect the battery maintainer it only take’s 5 to 30 mins to show fully charged again, depending on how many times I have pressed the starter.
