Simon
  • Topics: 1
I would only think its worn that quick if it’s been ridden hard, check the adjustment first, just slacken the cable a little & see if it makes a difference, replacement is easy enough to do its worth changing the small brass washer behind the basket (only found on the 650) as well, one other thing what oil are you using? this could be the problem.
