Apr 9, 2020 at 4:06 AM
#4191
The bike checks your kickstand switch and also the clutch lever switch before starting.
It is to prevent you starting in gear by accident or false neutrals.
Also when you ride around, its always checking that you pulled the clutch in before changing gear. if that switch was to fail while riding etc, it will cut off the sparks and bike comes to a halt. That for sure i know lol. So i wouldn’t bypass the clutch switch, just keep the wires under the airbox free from water / corrosion and all is well.
