Jan 16, 2020 at 12:53 PM
#3714
There’s the bolts for the fuel tank, and apparently more connectors. And to remove the airbox, there’s a really fiddly screw that i need to access. Also when removing the fuel tank to remove the carbs, what hosings/tubes do i need to remove? Should i also cut the fuel with the twisty NORMAL, RESERVE and OFF lever and let it run dry before pulling it off?
