Erwin
  • Topics: 1
Hi, Finally found the cause of the problems.
There are two big spacers in the clutch assembly, item nr 4 p/n 09160H20002 in the drawing of  the parts catalog below. These spacers are prone to wear at their contact areas and this may cause vrbration in the clutch assembly with the clutch lever in rest position. The noise disappears as soon as the clutch handle is activated or when the engine runs just slightly above idle speed.
Replacing the spacers the problems disappeared completely. A cheap fix all in al and not very hard to do once the problem was found.
Hope this may be of use to other 650 riders.
