Erwin
  • Topics: 1
Hi Marcel,
Thank you so  much for the tips, I will look in to this and inform you of the results later.
Got the service manual already, it should be easy to follow that. Already dismantled the clutch, thinking it might be the culprit, most likely the bearing,. Will check each item later this weekend.
Regards
Erwin
