Jun 18, 2019 at 8:21 PM
#2888
Hi,
Sorry it took so long.
I eventually was able to devote some time on the project. I decided to work my way around all the connections that connected to the EFi control unit, one at a time.
A slow process. Disconnect each connection, clean, electrical grease then reassemble, test effect! Move on!
The solution proved to be the “Side Stand Switch”.
I then continued to service all the connections.
I’m sorry I can’t claim any earth shattering results. Once again as with most projects, a methodical approach resolved the issue.
It took quite some but I believe it is unlikely that I will have a reoccurrence. it seems to have taken seven years to happen the first time.
Regards
David.
