Clayr
  • Topics: 2
  • Country: United States
  • Bike Model: 2015 Hyosung GV 250 EFI
GV250 EFi uses two cables at the bodies, so you may wish to talk to the seller that he may have sent a 650 cable by accident ? This below is the real GV250 cable i removed myself. https://www.ebay.co.uk/itm/257417684499
seller confirmed I have the right cable. It may be the case the I’ve routed it wrong. I’ll try again and add pictures of how I route it.
No problem but you must have two cables opening the front and rear cylinders then it becomes ONE at the throttle grip (2-in-to-1) style cable. You got this!
Throttle issues are back 🙠It was gone for about 2 or 3 rides. Now, sometimes the bike will buck at low speeds, no throttle response when coming away from a stop, or it won’t go past 52mph regardless of gear. FI light turns on occasionally but then turns back off. I’m thinking it’s the TPS but I have no way of accessing it.
