Aug 11, 2026 at 9:58 PM
#23284
GV250 EFi uses two cables at the bodies, so you may wish to talk to the seller that he may have sent a 650 cable by accident ? This below is the real GV250 cable i removed myself. https://www.ebay.co.uk/itm/257417684499
seller confirmed I have the right cable. It may be the case the I’ve routed it wrong. I’ll try again and add pictures of how I route it.
No problem but you must have two cables opening the front and rear cylinders then it becomes ONE at the throttle grip (2-in-to-1) style cable.
You got this!
