Ashley
  • Topics: 0
Only thing I can see this being is the same issue that happened to mine. It’s called a Falt spot where the bike bogs down at 5-6k RPM / way to work around this is CDI unit under the seat to cut the green & blue wire & then use some electric tape to secure it. It was a video I seen on YouTube that helped mine. Hasn’t bogged down since! Hope this helps
