iyGT3k
  • Topics: 5
Also just to touch on the clocks I’m using, I’m using mk1 bandit clocks which use the analogue speed cable I haven’t had to worry about anything in terms of wiring.
Both wheels are 17″ and run 110/70 tyre (600 only, 1200 uses 120) so the gearing should be the same and register the same speed I’ve tested this a little with rev matching in top gear and it seems to be correct – I’m using the hyo tacho.
The only issues I ran into was the little rubber gromets for the bulbs were a little smaller on the high beam and neutral cluster but other than that the bulbs are similar if not the same, one’s too big for the speedo housing but I just used the fuel level one for now until I can be bothered to switch it over.
