Apr 13, 2026 at 12:29 AM
#22288
Hallo o/
Stay away from those small cyclist ones, if you have amazon try grab it off that anything low to mid range would do.
The wheel alone needs to be 115nm iirc, I have an ebike here that calls for 50nm on something I can’t do up under torque and that is SERIOUSLY tight so 115 is being absolutely locked in.
Try find one with a 1/2″ drive they tend to offer more torque usually well within to 200nm and up, 1/4th tend to be way lower (usually bicycle ones).
A friend would say it wouldn’t need to be under torque but it definitely does and needs to be as accurate as possible – Try your absolute best to never drop it or plonk it down on a hard surface.
