Feb 24, 2026 at 8:36 PM
#22004
From your video , it says 2 flashes then 1 single flash = 2 _pause_1 is that right ?
Also what ECU is it using right now as 2013-2014 was the final year some countries were still using the infamous DAEWOO ECU and 2012 is the real year Hyosung started using a DELPHI ECU
Then also try to unplug the battery for 24hrs (or overnight) then plug it back in, Turn the Key On. Dont start the bike. But flick the Kill Switch 3 times quickly , this should trigger a flashing sequence.
If not, it probably will flash when you ride (meaning a problem happened while riding)
Do you also get flashing red lights when riding yourself even if its brief ?
