Dec 6, 2025 at 7:49 PM
#21395
Looks great!
If the headlight is able to be opened, you can replace normal bulb with OSRAM NIGHTBREAKER LASER or PHILIPS XTREME VISION MOTO for bikes if you ride in the dark , the LED’s inside your headlight are for daytime riding anyway.
I like those saddlebags , i will check them out. I tend to use SHAD EU products including tank bag I have now.
Motul 300V is recommended oil. Motul 7100 is also good. I trust these oils more than other brands i’ve tried for more than 20 years.
Motul Cool Factory Line (is the best coolant i have used) , do this when you service the radiator next time. I think it should be 2 years replacement interval (last time i checked!)
