Viewing 5 reply threads
    • #21379
      Gabor Horvath
      Hi, I am in Hungary
      I have a new model with 6 gear (GV 650, prod Y: 2024).
      My bike is a bit more than a year old an fortunately do not have any issue with it. I’m just wondering where could I purchase  any spare part in the future. I think more or less the technical construction is the same as the older model. Which is surly different is the speedometer, head and tail light (they are fully led operated), the double muffler system and the 6 gear drive.  I have sent pictures to the administrator (I suspect, Marcel was that guy) about the bike and the electronic parts and soon got suggestions how to upgrade my bike. My question was answered just after the registration date. I have ordered the new parts and installed them. The story will continue soon.
    • #21384
      Gabor Horvath
    • #21385
      When i heard the video of the bike roaring to life, i was blown away and it is still using ans OEM exhaust, at this point i can 100% say Hyosung did a good replacing that huge bazooka exhaust from previous models to now using twin stylish pipes , i can see they have some bulk in in them to reduce the growling noise! (more noise is good for me but i go deaf faster haha!)
      It looks very stylish without changing its original looks too much ,  I don’t know what else i would change in terms of visual appears , the dashboard with RPM meter was needed 20 years ago!  – But hey . they finally did it!
      Do you have plans to change anything outside ?   – Tail Panniers and Top Box ?  I see you got the rack fitted on the rear of the bike
    • #21389
      Gabor Horvath
      Hi Marcell,
      First of all thanks for Your suggestion, what to be replaced to have a more stabil operation in the future (regulator/rectifier, laser plugs, NGK plug caps, coils). I’ve repalaced all of them, cold start ok, final test will be next spring. What accessories I equipped is the engine guard, windshield, C-bow for the Hepco & Becker side bags (not on the pictures) and rear rack. I have a sissy bar too but not installed yet.
      I’ll attach an original picture without any  accessory and the side bags.
    • #21393
      Gabor Horvath
    • #21395
      Looks great!
      If the headlight is able to be opened, you can replace normal bulb with OSRAM NIGHTBREAKER LASER or  PHILIPS XTREME VISION MOTO for bikes if you ride in the dark ,   the  LED’s inside your headlight are for daytime riding anyway.
      I like those saddlebags , i will check them out.  I tend to use SHAD EU products including tank bag I have now.
      Motul 300V is recommended oil.   Motul 7100 is also good.  I trust these oils more than other brands i’ve tried for more than 20 years.
      Motul Cool Factory Line  (is the best coolant i have used) , do this when you service the radiator next time.   I think it should be 2 years replacement interval  (last time i checked!)
