lumentive2019
  • Topics: 2
  • Country: malaysia
  • Bike Model: hyosung gt250r
thank you for the suggestion marcel. I will ask my brother who used to repair his own bikes to do it, since currently I’m working outstation.
other than that, are there any temporary fix to this problem? as example, if the ets fi error code blinking, then based on the result we tested ourselves, the ets sensor is faulty, can we just unplugged the white socket from the ets sensor (ets sensor remain in place), and run the bike as usual? if ecu don’t get input from ets sensor, will the ecu use default mode or any other mapping mode that will automatically turn on cold-start fuel enrichment or ignition? so that it can start easily. I don’t mind about fuel consumption, because it is for temporary fix only.
and what will happen if we unplugged the white socket from ets sensor and unconnect the battery terminal for several days? will it reset the ecu and trigger cold-start mode?
