thanks for the replies. I will look into those after this. I forgot to mention that the FI light is also on. then I turn on off key 3 times, FI light blinking x10 x1 x1 x8, which I think the error code is 0118. I found out online that error code 0118 is related to WTS (I assume it is same as ETS= engine temperature sensor) Is this also possible cause to my bike problem?
If the ET is fautly , the ECU won’t know how to keep optimal fueling as the heat rises , so it has to sense it.  However fortunately, you can always remove the ET , get 2 bowls.  Cold water and  50% hot boiled water. Get a mercury thermometer in there to get glass readings
If the cold water says 7C degrees ,  put the sensor inside , get someone with a meter to help you.  your hands hold the sensor down to the water but do not allow the “black part” to touch water as it will corrode the pins!
The 2nd person will get a meter out and switch to  100 ohms ===> sensor says  25.5ohms and manual says around 0-10c sensor should be about 30 ohms .  Repeat the same process for the hot bowl.   These numbers are not true ,  I am just guessing, the 250cc service manual will tell you the real numbers to look for.
This way you can verify if the sensor is working according to different temperature or if it is behaving faulty  (skippy , jumping numbers etc….) , then yes replace the sensor.
It is also very important to make sure the tiny connector is clean and its plug,  if there is a bit of rust  / oxidization,  it means ECU gets less optimal feedback or zero feedback as the current is not enough for the ECU to sense it.
Just like fuel tank, if the float is at the bottom it could say zero ohms ==> dash board says hey your fuel is empty , and a full tank will have a high float, the fuel sensor will report 250 ohms , dash will say you have full = bars of fuel.
Ohms are very important readings for the ECU for sensor like Temp,  Fuel , Coils (Stator) , etc
