Oct 17, 2025 at 9:11 PM
#21001
I assume you mean #7 and #8 ? – They just literally slide out , but sometimes may need a little bit of a shake incase it catches the bearing cage lips , these spacer tubes also help the pivot bar roll on the needle bearings easier.
Normally that area is heavily greased including the pivot bar , bearings, and spacers to avoid seizures.
