No problem, take your time.
DELPHi is Hyosung’s better ECU and Delphi is used on many bikes besides Hyosung. In the past they did use Mitsubishi Japan ECU’s but because Mitsubishi is not making them anymore, there was a rough period around 2009 to 2014 where they used a Korean made ECU called Daewoo, most failures come from that particular ECU.
Ring my trade partner (oldest hyo dealer in UK) and ask them for the ECU as they may still have it on their shelf , it’s a small shop so expect a busy line but they do help when you are connected to them hopefully. They are called Startright Motorcycles (if i can ‘t get the ECU or they can’t , then i doubt anyone else in the UK supply chain will have a brand new one , leaving us to resort to dark-corners of trusting mr. unknown to buy a 2nd hand ECU on places like ebay etc but let’s hope the ECU of yours is still intact before it needs replacing.
Relays = eBay (there is a few used ones by various sellers there i am sure) , if not i can supply new ones (japanese ones).
Fuses = Either the tray will use Mini-Blade or Blade Fuses = Halfords / Any Local car shop.
When you get back, show us some pictures of your electrics so i can quote you back on this:
Am hoping its pretty simple like u say, mines a 2018 and i had to swap a big square main fuse over from 2 connectors at the back on LHS, could it be those is one the fuel pump fuse too (thats now been swapped/taken out?)
